WHICH 32" WIDESCREEN FOR £600
Discussion in 'TVs' started by terry h, Jan 24, 2005.
  1. terry h
    terry h
    Jan 24, 2005
    13
    I decided a couple of weeks ago it was time to buy a new TV as my current one is on its way out.
    I thought this would be a fairly straight forward process but after looking for the last couple of weeks I still can't make up my mind.
    My budget is £600 and I am looking for a 32" inch widescreen. I'm not sure if I should go for 100 Hz OR 50 Hz - some of the posts i've read seem to be quite negative about 100 HZ TVs and i dont know if its worth paying extra for this feature.
    Can anyone recommend a decent TV for around £600. Any advice would be greatly appreciated.
  2. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    There are many factors to look at if you are thinking of going to buy a 100htz set.If you sit close to the tv,watch a lot of live football on sky,how big your last tv was.These are just a few but basically you need a GOOD demo in a store.The things i mentioned before are some of the negatives.The positives are,Improved definition [better on larger screens],less flicker[if your eyes are sensitive],great for dvd playback.Whether the pros outway the cons has always been an interesting debate.Which is why you should see for yourself before committing.
  3. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Can't go wrong with a Sony KV32FX68.
    £600 including stand. Bargain.
