Which 32" TVs have component video input?
Discussion in 'TVs' started by Raze, Dec 21, 2003.
  1. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    Hi All
    Does anyone know or have a list of 32" (UK) TV models which have Component Video Input?
    Also does this give better quality than RGB Scart? (from DVD or games console)
    I am looking for the best 32" TV which woul dmainly be used for an XBOX and DVD playback - is the 32fx68 anygood for this?
    thanks for your help. :)
  2. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    I suggest you do some searching on 'progressive scan', as this is available via component RGG leads and on certain DVDplayers and TVs. What I list below in my sig. does this for NTSC format. More recent DVDplayers and TVs may also do this for PAL format.
    Good luck
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Panny PD30 and TOSH PF models have PS and component, note prog scan and component are different. some JVC32x37 i think has or will accept component a list is unlikely but try it in a search feild at a few retailers.
  4. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    Hi Horny
    I'm in Newport!! What about the 32ZD26P? Do you sell it? Can you price match it to around £700 ???
  5. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    The X37 doesn't have component or progressive scan but the HV-32P37 and the older HV-32D25 do.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Dont do tosh sorry mate Do do JVC Panasonic etc :blush: JVC model numbers arebloody confusing though!
