Which 32" TV is best for XBOX? (and DVD)
Discussion in 'Xbox Forums' started by Raze, Dec 21, 2003.
  1. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    Hi All
    I'm sorry if this question has been done to death (but I couldn't find it if it has..) but what is the best 32" TV to get which will be used purely for watching DVDs and playing the Xbox - I was looking at the Sony 32FX68, is it any good for the Xbox? Are there any 32" TVs that have component video input? (so we could use the HDTV facility on the xbox?)
    Also are there any other considerations to bear in mind? I heard that Sony TVs were not so good for consoles - any truth in that?
    Anyone got a list of component video input compatible 32" TVs?
    Sorry for all the questions and thanks for your input!
  2. CMcK
    CMcK
    Mar 18, 2003
    391
    Scotland
    +28
    Have a peep at the TV forum for TV advice.
    Personally I use a 32" Loewe Aconda for my consoles and DVD and it's a fantastic piece of kit. Even the PS2 looks pretty good through this set. The DMI setting is great for smoothing out choppiness and aliasing in older games.
    The biggest problem I had with my old Sony set and my consoles was the auto aspect ratio switching. It was useless at that. And the PS2 seemed to rob 25% of the TV's volume. And the DC robs the picture. As does the Saturn.
  3. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    hi CmcK
    Does it have component video inputs?
  4. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I have the Toshiba 32ZD26P, which is a superb TV. It as component input and supports Progressive Scan, but only NTSC, so you'll have to use a US (or chipped Xbox) to benefit.
  5. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    Hi Willy
    Please tell us more about your TV! Whats the picture like? better than the 32fx68s WEga tube??? I've always liked toshibas, but have found Sony is the king of Style (xcluding the toshiba Picture frame which is THE King (but in the 36inch version i think Sonys equiv is actualy bigger -screensizewise-)
  6. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I think the picture is pretty spectacular, and it's really highly recommended by the magazines etc.
    Take a look in the TV section of the forum. There used to be a monster thread on this TV from when it first came out. A few people had a few technical issues early on, but I've never had a problem with it. I love my TV.
  7. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
  8. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
  9. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
  10. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Try doing a search at http://uk.pricerunner.com for the best price.
    Personally I'd try to get your local John Lewis to pricematch the RGB Direct price (they'll only match internet retailers that have storefronts - RGB have one). If you buy from John Lewis you get free 5 year warranty and reliable customer service etc. That's how I did it anyway.
  11. CMcK
    CMcK
    Mar 18, 2003
    391
    Scotland
    +28
    The AV2 input on the Aconda accepts component input via Scart but it does not support progressive. It doesn't really need to as RGB etc is converted to 100Hz progressive anyway.
  12. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    how much is it CMcK?
  13. CMcK
    CMcK
    Mar 18, 2003
    391
    Scotland
    +28
    Look around and you should be able to get one for about £1200 or maybe less. Some of the other TV's in the Loewe range can be found for under a grand.
    Loewe sets share a common chassis and the various sets are very similar in terms of picture quality.
    More expensive models have more features as you would expect.
    There's also the ability to upgrade the TV's with sattelite decoders, VGA input etc.
  14. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    cor blimey 1200 quid! u can get a 36 inch sony for an extra hundred!
  15. w3dal
    w3dal
    Aug 4, 2002
    4,935
    Chelmsford, Essex
    +548
    These Loewe Tv's do come with an expensive price tag.
    Personally my 32" Sony Wega Is Faultless. Infact it had the best picture quality i could find on any 32" set under a £1000 which is why i bought it - ;0) and i looked at quite a few.
    Dal
  16. hencole
    hencole
    Personally I find you can't go wrong with the Beovision 3 ;)
  17. Kristian
    Kristian
    Oct 1, 2002
    2,189
    83
    Sunny Scunny
    +419
    Raze,
    Sorry for butting in but does it have to be a TV? For the prices mentioned above (£700-£1200) you could get a panny AE100 projector or something similar and have a 6 foot screen to watch DVD's and play games!
    Just a thought.
    Kris.
  18. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    hi KrisLee
    How much is it? (the AE100)
    Also - I've never really thought the quality on projectors were that good (?) maybe the technology has changes... for a perfectionist would a projector do a DVD justice?
  19. Kristian
    Kristian
    Oct 1, 2002
    2,189
    83
    Sunny Scunny
    +419
    Hi Raze,
    I don't know that much about projectors, just what I've read on this forum really. I do know that you can get the Panny AE100 for about £7-800, plus a decent screen for £1-200 and you'd have a big, good picture to watch films and play games. How it compares with a TV to a 'perfectionist' ;) will be up to you :)
    Most projectors can play Progressive Scan, PAL and NTSC, which will improve your films no end compared to a non PS TV.
    You're best bet would be to browse the rest of the console gaming bit as well as I'm sure people on there will be playing games on projectors.
    Sorry I can't be much more help but I can't comment too much because I'm still playing games on my TV - Tosh 32ZD26 - which is still very good.
    Kris.
  20. tonyeck
    tonyeck
    Personally, I would go for a projector in this day and age. I have a panny ae200 from digital direct for 700 quid and is certainly the best purchase I have done in years!
    any questions, ask away....
  21. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    How often do you replace the lens/bulb/lamp? Are they expensive?
  22. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    is it wise to run a projector only, I have a 32" pansonic set but don't really have the height for a projector screen and a tv so would consider selling the tv and using the projector for everything if it is fesible. Or would it be expensive/impractical?
