which 32" lcd would everyone recommend?
Discussion in 'LCD & LED LCD TVs Forum' started by jpb82, Dec 29, 2006.
Tags:
  1. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    hi
    ive been looking for a new HDTV mainly to be used for
    x360/ps3/pc gaming(eventually)/standard sky and dvd's
    i haven't ruled out a 40" but because of the room size
    a 32" tv would probably be more suitable.
    as for my budget i have around £1600 which is enough
    to buy any 32" tv on the market today and i want the best
    the tvs im thinking about are the philips 32pf9731d
    and the panasonic tx32lxd600
    the philips 32pf9731d is the most expensive 32" lcd
    on the market today and according to what hi-fi
    is worth every penny saying its the best 32" lcd
    they have seen with the panasonic a close second
    however all of there tests only involved sky-hd and dvd's
    absolutely no gaming so i have no idea which screen
    produces the best PQ with HD gaming.
    if anyone has seen any HD gaming footage on either one
    of these lcd's could you possibly let me know which screen
    produces the best PQ.
    thankyou
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I would look at the Sony KDL-32S2500 (if you can find it yet) and the KDL-32V2500 if you want the Wide Colour Gamut backlight, or alternatively, perhaps the Toshiba models. The Sonys aren't perfect (no TV is) and have a slight video processing quirk (which a lot of people won't notice), but the Samsung/Sony LCD facility makes the best panels that I've seen as of yet.
    I wouldn't buy a Philips LCD because you can't adjust the backlight brightness, only the pixel brightness, and I think you need both adjustments fo ra pleasing picture.
  3. rimmera
    rimmera
    Apr 24, 2004
    9
    Do you think there is anything particularly wrong with the Panasonic - is it free of any kind of edge sharpening/halo bugs which would make it decent for SD/PS2/GC?
    Paul
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Never used it, so I can't say, sorry! :thumbsdow
