Which 32 inches Toshiba TV to buy
Discussion in 'General TV Discussions Forum' started by Legendary, Sep 7, 2003.
  1. Legendary
    Legendary
    Jan 22, 2002
    412
    Walsall
    +11
    As long the TV support progressive scan PAL and NTSC and have a flat screen 32 inches widescreen.
    Which TV is best for my need in gaming, football, DVDs, and Sky Digital. Also what the different between Straza and picture frame TV ? Which one have a smaller backside. As it will be in my bedroom.
    I used NTSC (Both US/Jap) gamecube and XBOX (USA) and intend to get a Silver PS2 new model due next month (plan to chip it) and Sony 735 DVD player.
    Do I need to get a progressive scan DVD player for the TV as I got Component sockets for the TV.
    I am planning to get one in November, I got a Philip 24 inches widescreen which is average for me as there is a red glitch in pictures after white fade screen and is too bloody small for football :(
    Is there any other brand worth a look apart from Toshiba for progressive scan display.
  2. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Heya,
    I'm pretty new to this, but it seems that you need both a progressive scan player and compatible TV to get the most out of it.
    I'm pretty stuck on what TV to get. I was sold on the Toshiba 32ZD36, however it's only NTSC prog scan... not much use really. I've then looked at the Panasonic TX-32PH40, but I've seen mixed reviews - some rate it, some say it's mediocre. I've also looked at one of the Hitachis: prog scan yes, but only two scart inputs and no composite input....
    I'm building a 5.1 system, so I'd prefer just a Nicam set, rather than paying for extra features that I won't use.
    Well I'm confused. Let me know if you have any luck (or if anyone else can make a suggestion).
