which 32" CRT set?
Discussion in 'General TV Discussions Forum' started by kernaali, Sep 24, 2003.
  1. kernaali
    kernaali
    Which 32" CRT set set has clearest picture and can tolerate hig res if i hook my pc on? thx for advance.
  2. kwangomango
    kwangomango
    Jan 9, 2003
    859
    Kent
    +38
    If you get a Loewe with a VGA card it will accept a PAL signal up to 1024X576 and an NTSC signal up to 848X480. The Loewe picture is already sensational there is a massive leap when using a PC and the VGA card. More info here--> http://www.htcentral.net/community/viewtopic.php?t=500
    Not sure if there are any other sets which accept a VGA signal.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    best 32" picture is a beovision 3 from bang and Olufsen
  4. kernaali
    kernaali
    is there a net store that sells Loewe and delivers to finland?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Kernaali if you are in finland finding Loewe and B&O should be really easy! Try the Loewe website for dealers in finland and B&O for B&O dealers!
  6. kernaali
    kernaali
    if i use hdtv like HV-32P37 will it endure higher res?
