Which 32" 100Hz Widescreen?
Discussion in 'General TV Discussions Forum' started by rowbos, Jul 9, 2002.
  1. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    I have spent some time reading other peoples threads on this and related subjects (and cant decide what to buy)...
    I need some objective input on which 32" 100Hz widescreen to go for, i need Nicam, 3 scarts, flat screen, silver.
    And hopefully no geometry, or scrolling, or buzzing problems etc!
    I plan to use NTL Digital Cable, DVD, Video and Playstation on the TV.
    Thanks for your suggestions,
    Steve.
  2. Squirrel God
    Squirrel God
    Sony KV32LS60 ;) If you search for "KV28LS60" and "LS60" you'll find my review and some comments on this set.
    The Tosh picture frame is also very good as are the Loewes. ;)
    No doubt others will recommend some other sets, but that's at least 3 to put on your shortlist. Make sure you try before you buy ;)
