which 24" television
Discussion in 'General TV Discussions Forum' started by nig28, Oct 17, 2004.
  1. nig28
    nig28
    I am thinking about updating my TV and looking for a 24inch model. I have seen the Philips but I am not keen on the shape. I do like the Sonys but havent seen a 24inch.
    Who makes a 24inch widescreen, digital, I hope to get a seperate AV system so sound is not important.
    Nigel
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Nigel,
    24" is considered quite small today, particularly in the widescreen shape.
    (How times have changed. My parent's first TV was a 9" Ferguson.
    12" was considered large, and 15" enormous. But I digress...)
    Have you considered 28", which will give you a much wider choice?
    However, if it really must be 24", there's a selection of 16 on Kelkoo, including the specs and a picture.
    Hope this helps.
