Which 20Gb player for connection to hi-fi system?
Discussion in 'Headphones, Earphones & Portable Music' started by Kjetilb, Feb 12, 2005.
  1. Kjetilb
    Kjetilb
    I am in the market for an MP3 player that sounds well when connected to an amplifier. I have my eyes on the Sony HD3, do you guys think it's the right choice? Sound quality is my number one priority... I'm grateful for any advice! :lease:
  2. Signer
    Signer
    Yeh, i have the sony hd3, havent tried it, u sure it does connect? if so, with? yes im not experienced in this business
  3. Doomke2k4
    Doomke2k4
    I think, id you want realy good sound you got to use a Golden 3,5mm Klinke. The Player wont be the Problem, the Cable could be one.. If you want realy great sound spend some more Money for a High Quality Cable :)
