which 1gb duo pro card?
Discussion in 'Nintendo Forums' started by radicalrad, Jun 22, 2005.
  1. radicalrad
    radicalrad
    which is the best do you reckon for the psp....
    sandisk..
    sony...
    or the ultra II ?..Is this worth using in the psp? would psp taka advantage of the faster speed.
    thanks for you help guys
  2. aidey6
    aidey6
    Dec 12, 2003
    416
    2
    Warrington
    +67
    Sandisk make the ms duo for Sony..
    You may as well get the "standard stick" as i do not think the psp writes any quicker
  3. chrislad
    chrislad
    May 6, 2005
    5,816
    83
    Rep. of Ireland
    +145
    I have a Sandisk 1gig. It's working pretty well for me.
