Which 10cm speakers to replace stock?
Discussion in 'Video Streaming Boxes & Services' started by incywincy, Jul 27, 2005.
  1. incywincy
    incywincy
    Jan 25, 2004
    67
    Manchester
    Hi everyone,
    I'm going to replace the head unit in my Fiat Cinquecento for the Alpine CDE-9845R and thought while I'm at it, I could replace the stock 10cm speakers as well. As this is my first upgrade, I want to keep it as simple as possible, and was looking at either Alpine SXE-1025S or SPE-1002 .
    Will I get a reasonable improvement in sound quality, or can anyone recommend any other speakers that might be better, given the limitations that they need to fit in the original gap (the stock speakers are 10cm / 4").
