which 100hz TV to buy-under £400?
Discussion in 'General TV Discussions Forum' started by mt50, Mar 12, 2006.
  1. mt50
    mt50
    Oct 24, 2002
    1,676
    stoke-on-trent
    +139
    hi, i need to buy a new TV as my old 21inch sony has had it really the scart socket has dry joints so keeps loosing the picture, and it's really old now.
    i'm looking for a 28inch TV(as it's for a bedroom) and i think a 32inch may be too big but if i could get a good 32inch tv i would take a look at it.
    needs to be 100hz as 50hz TV's hurt my eyes(i can see them flickering)
    2/3 scart sockets(1/2 RGB)
    don't need it to be a great set as i will only be using it for a year or so, as HiDef will be my next upgrade.
    so something under £400 is what i'm looking at, if i could get it under £350 then that would be great.
    thanks
  2. Churnobyl
    Churnobyl
    Sep 22, 2005
    219
    swansea
    +5
    bought a panasonic tx28pm12 few weeks back,great picture detail and smooth,the only weak point i can find is the sound lacks depth. paid £320 at currys
  3. mt50
    mt50
    Oct 24, 2002
    1,676
    stoke-on-trent
    +139
    hi, how is the geometry of this set, we have got the PL10 downstairs and it's a bit off towards the edges but not too bad.
    thanks will take a look.
