which 1
Discussion in 'Subwoofers' started by snig300, Feb 3, 2009.
  1. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    hi all
    which sub would best go with a denon 2309 and b&w 685 and 686s im thinking XLS200-DF MK2 or a b&w 608 cheers for any help ,mainly for fims and a bit of music, room size about medium,got about £300 to spend
  2. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    looks like the most votes are for the B&W 608 cheers all for the help:D
  3. Member 639844
    Member 639844
    Former Advertiser
    Sep 2, 2007
    14,799
    Lancashire
    +1,182
    I think the real question is which subs performance best suits your ears. TBH it doesnt really matter what sub you choose as long as its good enough to intergrate fully into your system with its intergration featurs. The choice would simply be which of your chosen subs performs best and will intergrate best.
    I dont know enough about those 2 brands to give you the answer but matching to a particular amp isnt an issue. At that price though ive heard many a good word about the xls subs but never heard one myself. Not seen so much fuss made over the 608.
  4. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    ok that seems to make sense,so would the xls 200 be a easy first sub to get,I'll be setting it up with the auto setup on the denon 2309 to go with the B&Ws as I know nothing about manual setup,is it a plug and go type of sub?I was thinking the 608 might be a bit more idiot proof(don't know why I'm thinking that?)
  5. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    They're two subs of very similar size and so will likely have a similar profile of frequency response, thus both will integrate into the room and system just as easily. Brand matching is an audio, if not visual, non issue.
    However one has a much larger driver and a lot more power to back it up and will thus offer lower distortion and greater SPL/dynamic headroom under all circumstances.
    It ain't the B&W.
    B&W's nearest equivalent is the ASW-610/XP, which is the direct replacement for the older, but rather good ASW675. If it must be a B&W and needs to cost circa £300, then a second hand, or end of line example of the 675 would be worth searching out. Otherwise, just buy the XLS-200.
    If however, you have the £400 RRP of the 608 to dispose of, then BK's XLS-300 is a superb sub, with a noticeable dollop of extra low end grunt and even cleaner output at all frequencies.
    Russell
  6. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    cheers for that! looks like its going to be the xls 300 then:thumbsup: anyone got pics of it in place trying to get an idea of size the Dimensions 380D X 350H x 400W but are these in cm(or could it be feet:rotfl:)?
  7. Member 639844
    Member 639844
    Former Advertiser
    Sep 2, 2007
    14,799
    Lancashire
    +1,182
    Those sizes will be in millimeters.
  8. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    really!then better size than i was thinking, only 35cms tall cool.
