Which £2k speaker packages for Denon 3802?
Discussion in 'Home Cinema Speakers' started by ssuellid, Oct 22, 2004.
  1. ssuellid
    ssuellid
    Oct 22, 2004
    207
    +7
    Currently I have a Denon 3802 and a Mission FS2AV speaker kit.
    The DVD player will probably be a Denon 2910 - unless anyone knows of a better option for around £600?
    I'm looking to spend around £2k on replacing the speakers with either a 5.1 or 6.1 speaker kit. They have to sound good with music as well as film but also look good.
    All the speakers have to be the same colour and be of a light wood finish - birch, light beech etc.
    For positioning, the main speakers can either be standmount or preferably floor mounted. The centre can be either wall or standmounted. And all the rear/side speakers must be wall mounted.
    One final requirement is that any 5.1 packages must be easily upgradeable to 6.1 with another pair of matching same make/range speakers.
    So the only options I have found are: -
    Quad L series 5.1 package for £1930ish
    Acoustic Energy Aelite 5.1 for £1900ish
    Any other suggestions or thoughts on the above?
    Thanks in advance.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,267
    The Borders
    +2,572
    ssuellid
    Not quite meeting your 'all light wood spec' - the bipole/ dipole surrounds don't have the Maple side panel options you get with the rest of the range but theses are worth a look/listen.
    You can have a 5:1 System 2200 set up for £1.8k (UK SRP) and if you want you can replace the 2200c with the more upmarket (but similarly voiced) 4200c and just sneak in under your £2K ceiling.
    See - http://www.atlantictechnology.com/system_2200.htm
    Expanding the system is very simple and as the 1200, 2200 and 4200 systems all use similar drive units you can either add in a set of low cost 1200LR-S for rear effects or upgrade the front LR to 4200LR speakers and move the 2200LR to the rear (lots of options).
    Any questions please shout.
    Joe
  3. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    Monitor Audio Bronze/old silver/gold (should be able to fit in the budget with G10s front and back)
    JM Lab Chorus/Cobalt
    Mission M5
    B&W 600/CM
    I would ditch the associated subs and grab something with a bit more kick though.
  4. ssuellid
    ssuellid
    Oct 22, 2004
    207
    +7
    Thankyou - that gives me some more options to look at. I do like the look of the JM Lab kit. Never heard of Atlantic before. Thanks again.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,267
    The Borders
    +2,572
  6. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    You could probably get a complete mission 78 series setup for £2000 now.
