Question Where's the Sat input ?
Discussion in 'Samsung TVs Forum' started by cturner24, Aug 4, 2018.
  1. cturner24
    cturner24
    Sep 3, 2013
    9
    I've just purchased a T32E390SX, great, but can't work out for the love of me how I connect it to my Sat dish directly? There doesn't seem to be satellite connection input on the rear of the TV? I've everything else mind you - HDMI's, Arial, USB's and all sorts. Have I missed something here? Thank you for your help - I already know I'm out of touch with connections!
  2. simonlewis
    simonlewis
    Jul 31, 2014
    4,704
    stockport
    +1,757
    Don't think it has a satellite connection, did you check before you bought the tv ?
  3. cturner24
    cturner24
    Sep 3, 2013
    9
    I didn't ask that particular question, I took as granted like my Sony Bravia - it's meant to be a smart tv. Is there a way around?
  4. cturner24
    cturner24
    Sep 3, 2013
    9
    So this so-called SmatTV cant even connect to satellite connection in the UK?
  5. simonlewis
    simonlewis
    Jul 31, 2014
    4,704
    stockport
    +1,757
    Yep thats about right.
  6. cturner24
    cturner24
    Sep 3, 2013
    9
    *SmartTV
    Many thanks for your reply. So in summary, this TV literally isn't capable, in any way, of connecting to a normal sat cable?
  7. cturner24
    cturner24
    Sep 3, 2013
    9
    Are there any work-arounds that you know of? Different connectiond via the sat cable?
  8. cturner24
    cturner24
    Sep 3, 2013
    9
    So how do you actually get TV input on this Smart TV?
  9. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,265
    +1,886
    Smart TV has nothing to do with satellite capability. Smart refers to plugging it into the internet - either directly on the Ethernet or via WiFi to give you access to services like Netflix and Youtube etc.
    You TV will have a Freeview - terrestrial TV input, so you need a normal aerial connection. Failing that, a Free sat box will provide you with all the free to air channels.
  10. cturner24
    cturner24
    Sep 3, 2013
    9
    Thanks for your help, appreciated. I've been using a satellite dish for so long, I'd actually forgotten that you could still use a digital arial!
