Where's the HDD on H&B DRHD120
Discussion in 'Blu-ray & DVD Players & Recorders' started by tracy.charlton, Jul 31, 2005.
  1. tracy.charlton
    tracy.charlton
    Hi, hope someone can help. We have bought a DVDrecorder/HDD (H&B DRHD120) and followed instructions on set up. The DVD part seems to work fine but we cannot access the HDD in any way. The remote will not toggle between DVD/HDD, timeshift will not work and if you press record the only option is DVD. It is as if the HDD part does not exist - even the HDD format is disabled. Where are we going wrong?
    The first attempt we had sky>DVD>TV by both scart and Rf between each, the second attempt we took out sky and had aerial to DVD and then scart, Rf and yellow, white, red leads to TV. Still no luck. HHeeelppp!!
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Out of curiosity I downloaded the manual and had a look at it. It seems the remote DVD/HDD button should toggle to what you want to use when the machine is stopped. So if it doesn't then I would think either the box or the remote is faulty.
  3. tracy.charlton
    tracy.charlton
    Thanks for replying. We have sent it back and it is being exchanged. Hopefully we'll have better luck with the replacement, Tracy
