Where's my PIN ?
mattyg
Hiya folks
As the title states where's my PIN
Had HD installed yesterday but cant find anything relating to the PIN ohter that its in my T/C that came with the box but I've checked 3 times.
In the words of miss Pitstop
HAAAAAEEEEELP
If it is a brand new install then it is the last four numbers of your viewing card serial number, if it was an upgrade with the card being previously used in another box then it will not have changed.
mattyg
Found it
1st result when googled SKY + PIN came up with the solution on this site but couldnt find it when searching through this site.:rolleyes:
Default is the last 4 digits of the sky card
But i have to phone them to change it:thumbsdow
EDIT: or I could have waited 2mins and got 3 responses on here
You guys are great:clap:
mattclarkie
Sometimes your PIN isn't the last 4 digits of your viewing card as I annoyingly found out when I had Sky+ installed and the bloody multi-room viewing card had a PIN that was not the last 4 digits :rolleyes:.
I hadn't changed it because it was a brand new viewing card, so either the installer did it to be a :censored: or something went wrong at the viewing card factory.
