Where's my Midrange????
Discussion in 'Home Cinema Speakers' started by WBC, Dec 22, 2003.
  1. WBC
    WBC
    Guys,
    I got Mission M74i for my fronts using a Pioneer 811 Amp. Although I am reasonably happy with the sound, I do think it sounds a little bright and lacking in the Midrange area???
    Any ideas? The amp is set up, more or less 'out of the box' I haven't tampered with the eq's, incase, it ends up sounding worse?
    Is it down to the partnering or am I missing something?
    Stace :D
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    How long have they been run-in?
  3. WBC
    WBC
    Had them about 4 months, probably on for 3-4hrs a day minimum.
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    :D , OK, they are run-in then. I hate to say it without trying the amp and speakers together (in your room), but I have heard each seperately. The Pioneer is a bit bright and forward sounding IMO, while the M74i's are big and a bit boomy, with a slightly muddy midrange. You could try blocking/unblocking the rear ports & try moving them a bit further into the room, giving them more space to breathe.
    Unfortunately the brighter Pioneer and the warmer Missions just MAY not be a great match, whatever you do. Sorry. :(
    P.S. Nobber 22 whispers: (I'd think about changing the speakers first)
  5. WBC
    WBC
    Would the Large, Small setting come into play here????
    The rear ports are currently blocked!!!
  6. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    These speakers need PLENTY of space to sound they're best.
    At least 1m away from rear & side walls, otherwise the upper-mid becomes cluttered & the sound becomes rather congested.
    Dimmy
  7. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    If you have a sub, generally set to Small (but is is worth trying Large on some speakers too - IMO your's will work better on Small).
    If no sub, set SubOut = Off, then Fronts to Large.
  8. WBC
    WBC
    I do have a sub and the speakers are currently set to large, so I will set the to small when I get in.
    Let ya know how I get on!
  9. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Thinking further here Stace - what source are you using to spin the discs? DVD player or a dedicated CD player?
    A poor source machine may give the amp and speakers no chance to perform at their best. The player could be robbing the sound of any midrange.
  10. WBC
    WBC
    Using my DVD for both DVD and music. Mostly noticeable with music!
