Where's everyone buying their blubs from?
Jon79
Established Member
Price seems to vary quite a bit so wondering what is the best and cheapest place to buy a replacement blub? Looking one for my BenQ W1070.
Also, is it best to buy one that comes with replacement housing or just buy the blub itself and use the old housing?
grims dale
have a look at the make of original lamp that's in your projector if you can buy it without the housing cheaper and fit it in yourself but be careful not to touch the glass as the oil from your skin can blow the lamp when it heats up
you can cheaper lamps but thay May damage
your projecter also trying to fit a new lamp in the old housing can be fiddly and you can damage the new lamp
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
