Where you can see a PH Panel
Discussion in 'Plasma TVs Forum' started by geebeeone, Dec 29, 2006.
  1. geebeeone
    geebeeone
    Oct 20, 2006
    161
    South Wales
    +5
    I do not know if it is a SD or HD panel, but if you go to most Harveys Furniture stores they have a silver panel showing dvd.
    They do not have any other feed for you to watch, but at least you can see how attractive and slim the panel is, plus the picture of the dvd using just a basic connection is superb.
  2. rwttm001
    rwttm001
    Sep 25, 2006
    1,811
    Leeds
    +118
    Or Asda, local shopping malls, pretty much everywhere if you look! Get close up and look at the model no on the front...
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That's a PWD8 or PS9, depending on age. They are unburstable, cheap and very very effective for SD video. They do not sell nearly as much as they probably should to home cinema enthusiasts. For those with limited HD ambitions for the next few yrs, they are still the dogs dangly bits. Then, whe HD becomes mainstream, put it in the kids' playroom and let them try and trash it with their Wii, PS2, etc, along with continuous MTV. It can take it.
