Where would I buy a quality washing machine inlet hose?
RHCP
alnwrd
When you say both sides are leaking do you mean both ends? If so have you got washers installed, and have you fully tightened ?
IronGiant
They are supposed to be hand tightened, but often require an extra tweak with pliers or mole grips, as said, check the washers...
Dave
RHCP
OK I replaced the washers with the ones that where already on (they where fatter and bigger) and it seems to have solved the problem yey :thumbsup:
Every time I try to do a job something happens to slow me down, I'll be starting my "help me install a kitchen" thread up again soon, I've been working too much recently to get anything done.
Cheers folks! :)
RHCP
Yeah it seems ok for the minute so I don't want to move it :rolleyes:
I'll tighten it up when I have to pull it out again.
