Question Where to put the cinema door?
Triggaaar
I need to cut a hole for the cinema door. The door needs to go near the screen, and the screen will be on a baffle wall. The issue (AFAIK) is trying to avoid first reflections.
I'm wondering whether it's best to have the door really close to the screen, and hope to avoid first reflections hitting the listening position with the L&R channels off the wall a foot or two. Or should I move the door back a little?
This is the room before the work:
The baffle wall and screen will go over the existing windows. I anticipate that being about 16" deep. The existing door will be blocked up, as it's where the rear seats (and therefore riser) go.
What do you think?
mb3195
I’ve got a panel mounted on my door.
My door is fully sealed when closed, it causes me no issues.
I’d move your door back slightly though to give you a little more flexibility.
Triggaaar
Thanks Mark
It looks like some reflections are inevitable, so I'll need to put a panel on it either way. I think I have the choice between having the left speaker reflecting off the door and onto the main listening area, or both the centre and right speaker reflecting (but from a further distance).
Maybe if I get the panel on it right, it won't matter?
mb3195
Thanks Mark
Just for the panel direct on to the door mate, that’s all I’ve done.
Try to make your left and right panels line up in parallel identical to each other, even if it means a slight compromise to the overall position.
