Where to put my speakers?????
Discussion in 'Home Cinema Speakers' started by Complete Novice, Aug 25, 2005.
  1. Complete Novice
    Complete Novice
    Apr 19, 2005
    119
    19
    :confused: I have two speakers. Where is the best place to put them in a living room to get the best sound. Should they face a particular way and should they be at a certain height?
  2. skinnyfat
    skinnyfat
    Thats a sort of a 'how long is a piece of string?' question.
    There are a few basics obviously.
    1. Preferably at ear level when in the listening position - is the height you should be looking at.
    2. Placement becomes a little more tricky, depends on size, shape, contents of the room they're in. In front of the listening position obviously facing you will be a good place to start. 'Toe in' if you need to (turn at an angle towards you) and see which sounds better.
    Start with these and take it from there
    Skinny
