Where to put a Plasma
Discussion in 'Plasma TVs' started by richjthorpe, Oct 25, 2004.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi all,
    The only empty wall we realistically have to place a flat panel is on the opposite wall to the front bay window. The other 2 walls have a fireplace (Too high to put it on top of) or the door to the room.
    Because Plasmas are super flat, is it affected by reflection from windows opposite the screen ? Can this be recitified by tilting the screen downwards slightly ?
    With LCD panels not having a glass front, are these less prone to reflection ?
    Thanks all,
    Richie.
