where to purchase Kef Q's
Discussion in 'Home Cinema Speakers' started by EDnSKY, Feb 13, 2005.
  1. EDnSKY
    EDnSKY
    Feb 13, 2005
    17
    Westhoughton
    Hi all,
    This might sound odd but i am having trouble finding the Kef Q series in any shops here in the UK. Can anyone recommend anywhere either online or high street. I am in the north-west if it helps.
    cheers mateys :clown:
  2. simonn5
    simonn5
    Nov 4, 2004
    62
    Highbury
    Sevenoaks sell them if you have one in your area. Otherwise go to the KEF website and contact their customer service dept. for details of distributors in your area
  3. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    You can't buy them online due to Kef's policy of 'in-store' purchasing only.
  4. juniper
    juniper
    Dec 30, 2003
    1,903
    48
    +60
    I am reasonably sure that Creative Audio in Shrewsbury sell them - don't know if that is a million miles from you or not? :)
  5. Roger Matthews
    Roger Matthews
    Nov 11, 2004
    291
    Aberystwyth
    +15
    I think Juniper is correct, Creative Audio usually stock them and have excellent demonstration facilities. It would probably help if you tell them you are coming.
  6. EDnSKY
    EDnSKY
    Feb 13, 2005
    17
    Westhoughton
    Thanks for everyones help. Will have a nosey but might have to go for mordaunt-short range if i have to travel.
    thanks again :smashin:
