where to next (upgrade)
Discussion in 'Hi-Fi Stereo Systems & Separates' started by common, Jun 13, 2003.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I'm very happy with my system but upgrading is all part of the fun - where should I be going next with my system ?
    Meridian 500 CD Transport
    Tag McLaren DAC20
    Tag McLaren 60i amp
    Tag Mclaren 60p power amp (bi amped with 60i)
    B&W CDM 1NT's on B&W stands
    REL Strata II
    Lat International speaker cable and interconnects
    Russ Andrews power leads
    Was thinking of another 60p but perhaps new amplification all together is needed ??
  2. nathan_silly
    nathan_silly
    Change the 60i with the 60IRV, or the Tag pre-amp only add a another 60P or replace the 60P with two 100P's.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Joking aside,IMHO the best thing you could do would be to upgrade the power amps,and not from the Tag line-up.....I'm very happy with the Tag processor i have,but their power amps generally lack control and power,and that's based on my experience of their higher powered multichannel amps.
    I'm quite vikki and Steph would recommend some of the Rotel amps(as would I in their price range)or alternatively looking for some really good,older pre-owned amps....you occasionally find Krell KSA50's or similar at very good prices....don't be put off by the age or apparent 50W power ratings as these will deliver up to 400W into 1ohm loads.
    The CDM1NTs are quite a nasty load as regards impedance and reactance,and can trouble Tag amps.
  5. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    There is a Bryston 4B-ST offered on Loot at the moment.
    Krell amp is very serious piece but Bryston is not much behind.
    Anyway, I'll see you tomorow and if you have time you can listen to my system. Bring your favourite CD's.
  6. Bassline@ddict
    Bassline@ddict
    Dec 20, 2002
    456
    Iver
    +14
