where to get h/k dvd repaired?
Discussion in 'Blu-ray & DVD Players & Recorders' started by technovorgin, Nov 9, 2004.
  1. technovorgin
    technovorgin
    Jun 16, 2004
    226
    Leeds/Wakefield border
    firstly sorry mods if this is in the wrong part of the forum :confused:
    my harman kardon dvd player has gone awol :suicide: it wont display a picture through the (yuv) component the sound works fine but no picture i got up one day and thats how it was i checked the leads to the av amp then to the plasma but it still wont work
    ive put another dvd on to the same inputs to amp etc and that works fine so it has to be the dvd player
    i need a repairer that can test the component out etc & is it worth the expense etc
    thanks in advance & anyone around the west yorks area (leeds) if poss as the postage would be a killer
  2. Crocodile
    Crocodile
    Nov 4, 2002
    17,565
    +6,499
    Do you have any output from scart or composite? If so, is there a menu option to enable/disable component output that may have reverted back to disabled? May also be worth checking the manual for a default/factory reset.
    These are only suggestions as I don't know HK players.
  3. technovorgin
    technovorgin
    Jun 16, 2004
    226
    just tried it on scart it turns the tv onto av channel but thats it no sound and no picture
    it says progresive scan in the dvd display window and i cant find a video function button on remote or front panel to turn it to rgb but just a note the first time i tried it the picture was green and wavey like it wasn't tuned in but i hav'nt seen that again
    im at a loss
    does anyone know how to factory reset the player :suicide:
  4. Crocodile
    Crocodile
    Nov 4, 2002
    17,565
    +6,499
    What model is it?
  5. technovorgin
    technovorgin
    Jun 16, 2004
    226
    sorry for the late reply i had to work unexpectedly :eek:
    its a dvd 25
  6. Crocodile
    Crocodile
    Nov 4, 2002
    17,565
    +6,499
    According to p16 of the manual, pressing "stop" on the remote for 3+ seconds should revert from progressive to interlaced. If that doesn't help the only other thing I can suggest is disconnecting the player from the mains overnight & hope that resets it.
  7. Graham_E
    Graham_E
    Nov 8, 2004
    162
    +10
    I'll check with technical tomorrow, but as far as I remember, pressing clear whilst turning the unit on should do a full reset. If that doesn't work, ring the Harman office on 02087314670, and ask either Mark or Trevor.
    Regards,
    Graham
  8. technovorgin
    technovorgin
    Jun 16, 2004
    226
    cheers folks ill try to do them today as usual im stuck at work most of the weekend :mad:
