Where to get German r2 discs ?
Discussion in 'Movie Forum' started by dfield2000, Apr 30, 2003.
  1. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I noticed that cd-wow were selling 'The Boondock Saints' for £4.99, but it only has 2.0 channel sound. After looking at the dvd comparison website it looks like there are 5.1 versions around but they are either in the heavily cut region 1 format or region 2 releases except for the UK one.
    Can anyone tell me a website were I can buy a German r2 copy of this film ?
  2. Rambo John J
    Rambo John J
    Aug 11, 2000
    3,687
    Hanoi Hilton
    +916
    www.amazon.de is simple enough if you already have an amazon account at one of their other sites
  3. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    Thanks for that, but my German isn't very good. Is there anyway of getting the order screen in English ?
  4. juboy
    juboy
    Amazon.de doesn't appear to stock it.
    In Germany it's called 'Der blutige Pfad Gottes'. You can buy it here (although it's not cheap at c.£19!):
    www.1a-dvdshop.ch
  5. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    Apparently the R2 Japan is just as good as the german. Are there any UK sites that import ?
  6. juboy
    juboy
    The Jap version's great for being uncut, NTSC progressive scan and an exclusive commentary but it's only DD2.0. You might well find the Jap version ends up even pricier than the German.
    And this is the reason why the UK R2 and the US & Canadian R1s are so cheap... they're all bad compromises.
    An R1, unrated special edition would be nice.
  7. Squirrel God
    Squirrel God
    A R1 SE is apparently in the pipeline which should be uncut.
    For future reference, you can always use BabelFish to translate a foreign site as you click through it:
    http://babel.altavista.com/tr
  8. Rambo John J
    Rambo John J
    Aug 11, 2000
    3,687
    Hanoi Hilton
    +916
    Probably turn up about the same time as the sequel that's in the works
