Where to get DVD+R & DVD+RW discs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Too Tall, Apr 10, 2003.
  1. Too Tall
    Too Tall
    May 20, 2002
    495
    Milton Keynes
    +4
    Any suggestions on where to get the best price on DVD+R and DVD+RW discs?
    And do you know if they're any good, obviously if there £1 but don't work I'm not interested.
    Cheers,
    Too Tall.
  2. ferris57
    ferris57
    Jan 18, 2003
    869
  3. numskull
    numskull
  4. mike5
    mike5
  5. SASMAN
    SASMAN
    Mar 17, 2003
    117
    BRISTOL
    +3
    hi
    what is the best dvd-r to use with the HS2. around the £1 mark or cheaper,
    Tom
  6. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    I have had no failures with Traxdata, about £1 a go, but everyone seems to be out of stock at the moment, need some more myself
  7. ferris57
    ferris57
    Jan 18, 2003
    869
    Yeah traxdata are excellent. Ritek One are also excellent, in fact they are the same disc, just rebaged, for a little less money.
  8. thfccambs
    thfccambs
    Jul 17, 2002
    21,103
    White Hart Lane
    +6,897
  9. malcom
    malcom
    Aug 25, 2001
    526
    +4
    I use both the E20 and E30. Traxdata as far as I am concerned are a nightmare. I purchase a batch of 25 just before Xmas and 50 FWS which look like traxdata. Both Traxdata and the new FWS throw up the same unpredictable problems. Costing a little more I believe Verbatim are the best bet. No problems with them so far!!
  10. ferris57
    ferris57
    Jan 18, 2003
    869
    I have used datasafe yallow tops, blue tops, gold tops. Just about every ritek disk on the market (traxdata, infinity, whitelable) and have never had a problem with my e30. I think that they deffinately aren't created equal. A good move is too buy a sample pack and see what works for you, and then stick with it until it disapears (which seems to happen all the time!).
