Question Where to get cooling fan for 65dx902b?
Discussion in 'Panasonic TVs Forum' started by Trollslayer, Mar 29, 2018.
    1. Trollslayer
      Trollslayer
      Feb 11, 2007
      24,281
      Poole
      +9,572
      One is sticking (lots of dust in the house when i moved in, had to clean the fans a couple of times so need to replace just one.
      I will try getting some canned air but no guarantees.
      It's that or common the pulse signal from the adjacent fan to this one.
    2. arenaman
      arenaman
      Nov 13, 2009
      8,336
      +6,773
      You're welcome to one out of my dead (trashed) VT65 if it fits, free to a good home :)
    3. Trollslayer
      Trollslayer
      Feb 11, 2007
      24,281
      Poole
      +9,572
      I took the fan unit (two on a small chassis) and gave it the whizzy treatment - A Henry at full power on each side of the fan for 2-3 seconds several times, seems to have cleared it.
      I will give the cheap carpets that were here when I moved in a really good vacuum over the weekend to try and stop the problem.
