Where to get cable,tv link & remote
Discussion in 'Satellite TV, Sky TV & FreeSat' started by smallman28, Jun 2, 2002.
  1. smallman28
    smallman28
    I am looking to run a feed off of the RF2 socket on my receiver so my parents can use Sky when I am not at home.
    It has been suggested that CT100 would be a better cable choice other than regular coax as the run is likely to be about 20m,any thoughts?
    If thats the case does anyone have any idea who sells it online as well as perhaps the necessary tv link and an extra remote?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Your local DIY store should have the cable, plain coax can easily pick up electrical interference so a few extra pounds to get shielded cable is worth it.
    SKY sells the TVlink and remotes but this place is pretty good...
    Satcure
  3. smallman28
    smallman28
    Sorry to say I work for the local DIY store and we dont stock it!
    Thanks for the other link though.
  4. bjd
    bjd
    Feb 4, 2002
    2,832
    N. Ireland
    +825
  5. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    go to maplins.
    the ct100 looks ok & the is good too.
  6. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    sorry, i meant the price.
    whilst your there you might as well check out the ct125
  7. sam_a
    sam_a
  8. Bonesy
    Bonesy
    Feb 22, 2002
    1,168
    Wiltshire
    +31
    I bought mine from vision 2000, for £19.99, eye and remote.
    good service.
