where to get a right angled 3pin lead for my samsung
Discussion in 'Cables & Switches' started by evil genius, Jan 15, 2008.
  1. evil genius
    evil genius
    Dec 4, 2007
    183
    16
    warwickshire
    as above really.
    would you believe it, the lead that come with my R8 is about 150mil to short:mad:
    found a few but only 5amp. thinks it needs to be 10amp and must be right angles!
    thanks in advance foir any help
    ian
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
  3. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
  4. evil genius
    evil genius
    Dec 4, 2007
    183
    16
    warwickshire
  5. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    If the cable is rated to 13A then you just put a lower rated fuse in it to match your equipment but do check it really is 10A as 5A is more common.
  6. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    Entirely possible I agree, just emphasising the importance of being sure as it could be the difference between a blown fuse and a blown TV :)
