where to find push to open door catches?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by richard plumb, Jan 2, 2007.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,519
    Windsor
    +1,054
    bought all my IKEA stuff today, but couldn't find any push to open catches. They have some great ones that come with some of their units, but not separately.
    I'm looking for something where I can push to open a door, then push again to close. The ones in the unit in IKEA were magnetic, and I think might have had a special hinge to help them open fully.
    B&Q's website is rubbish, and google isn't helping too much either
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,519
    Windsor
    +1,054
    BTW, the units are all pretty heavy, but desinged to be stackable (even come with pins to stop them sliding around.
    But will I be OK removing the backs from at least half of the bottom unit to make room for my receiver? It'll have three other units stacked on top of it, each about 25Kg
  3. jonny round boy
    jonny round boy
    Oct 25, 2006
    194
    Halifax, West Yorkshire
    +12
    Richard,
    Screwfix do them. There's 2 types - an add-on latch, which you just fit to a door with standard (unsprung) hinges, or if the door has sprung hinges, you can simply replace them with these.
    B&Q do stock the first type, but they won't be on the website.
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,519
    Windsor
    +1,054
    cheers. Any idea what hinges normal IKEA cabinets usually have? I guess non sprung? and most likely a funny size so you can't use anyone elses fitments?
  5. jonny round boy
    jonny round boy
    Oct 25, 2006
    194
    +12
    Richard, what cabinets have you bought from Ikea? If you can provide a link to the range I may be able to tell which hinges they have.
  6. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
  7. richard plumb
    richard plumb
    Jan 27, 2002
    14,519
    Windsor
    +1,054
    they were BESTA units. Using mostly Norum gloss white doors, with a stripe of tofta gloss red to coordinate with the new sofa thats on its way.
    I found some magnetic push catches at B&Q so hopefully they'll be fine.
    Although the sight of 22 IKEA boxes stacked in various places around the house is pretty daunting !
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
  9. Hitman
    Hitman
    Feb 16, 2005
    25
  10. MISTERE1971
    MISTERE1971
    Nov 5, 2007
    85
    +5
