Where to demo
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Mike-M, Dec 2, 2004.
  1. Mike-M
    Mike-M
    Oct 13, 2004
    1,263
    48
    Lincoln
    +30
    Can anyone recomend some good stores to demo a wide range of gear. I have done my research and want to hear the like's of Cyrus, Linn,MF, ProAc, Castle and others in the same vein. There's nowhere where I live (Lincoln,they are very restricted on their ranges). I will probably have to travel, but don't mind this if I can get the choice.
    Also, due to room layout I really need the facility to adjust the Left Right balance which does not seem to be something a lot of the manufacturers I've mentioned provide. Is there another way around this (can't move the furniture, you can guess why!) or can anyone tell me if I can get kit with the control I need on it.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Hi Mike,
    I know on a lot of Linn equipment you can alter the balance and speaker setup. I don't know exactly which range you're looking at but this is certainly a feature on there higher end systems and 5 channel amps.
    Sorry I can't help with the 'where to demo' question.
  3. Paulholio
    Paulholio
    Id definately try www.frankharvey.co.uk, they were rated in the top 10 retailers in the UK by What Hifi. You should go listen to their Naim...very nice :thumbsup:
