Where to dem in the Northwest?
Discussion in 'Projectors, Screens & Video Processors' started by CDphobe, Mar 17, 2005.
  1. CDphobe
    CDphobe
    Jul 11, 2004
    1,128
    48
    Bolton
    +89
    Folks,
    Some advice from the assembled ranks please? Any suggestions for good dealers at which to look at a range of projectors in the Northwest? I'm based on Preston, so that would be great, or anywhere between Lancaster and Manchester/Liverpool. I'm fairly familiar with the audio shops in the area, but wonder if there are better specialist AV/projector dealers who can help integrate an AV set-up into an existing 2 channel set-up, and show me the options around the display equipment. Thanks in advance,
    Al
  2. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    I have had good service from Sevenoaks in Manchester town centre, I recently bought their own ex-demo Stewart Filmscreen Firehawk screen and an Infocus Screenplay 7205 projector.
    They had a few different models set up to look at and friendly and knowledgable staff.
    Hope this is of some use.
  3. cinemagary
    cinemagary
    Jul 27, 2004
    495
    Manchester
    +16
    I use Practical Hi Fi in Manchester on Bridge Street :) I have used them for a few years now, they have a large number of different amps projectors dvd players etc on demo. The staff there are very helpful and knowledgeable, I am sure you would get unbiased advice if you tell them what you are looking to do. :thumbsup:
  4. CDphobe
    CDphobe
    Jul 11, 2004
    1,128
    48
    Bolton
    +89
    Looks like Manchester is the place to be then! Thanks guys, I'll pop into both next time I'm in town and arrange a dem with whichever seems to have the best range for what I'm after. Thanks again,
    Al
