Where to buy S-Video and Componant video splitters.
Discussion in 'Cables & Switches' started by MacReady, Aug 5, 2005.
  1. MacReady
    MacReady
    Jun 25, 2003
    2,224
    Barnsley, South Yorkshire
    +108
    I want to output the Sky+ S-Video signal (via S-Video) and the DVD/Xbox signal (via componant) to both a projector and a RP TV but only have one S-Video out and one componant out on the back of my amp.
    Where can I buy simple splitters for both outputs so I can send the signal to both devices? I have had a look on Ebay but am reluctant to buy for fear that I will get a severe drop in quality.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,119
    Rainham Essex
    +2,388
    1:2 component buffer Here.
    S-Video switch with 2 outputs Here or Here.
    I've not used any of the above so can't say how good they will be. I have however used other JS-Tech boxes in the past and they have always given excellent PQ.
    Mark.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,041
    The Borders
    +2,518
    Cleric
    Why 'strangle' your system using S-Video from the Digibox.
    I'd suggest an RGB2YUV converter on the SCART RGB Output of the Digibox and switch both YUV sources via your AV Receiver and then a 1:2 YUV Distribution amp on the Output of the AV Receiver.
    The JS Technology kit works very well.
    Best regards
    Joe
  4. MacReady
    MacReady
    Jun 25, 2003
    2,224
    +108
    So if I was to buy this and this
    I will be sorted and be able to output two componant signal (one converted) to both my TV and projector?
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,041
    The Borders
    +2,518
    Hello Macready
    Spot on!
    Joe
    PS Keep in mind you need cables too!
  6. MacReady
    MacReady
    Jun 25, 2003
    2,224
    +108
    Yep, just starting to look at some more cables to buy (My Wife almost strangled me when I said I was goinmg to buy more..lol).
    Just wait till I tell her I will be spending £200 on those two boxes too ;)
  7. MacReady
    MacReady
    Jun 25, 2003
    2,224
    +108
    Am I right in thinking that the stuff from JS is recomended? I just want to make sure that there will be no drop in quality if I use any of these converters and splitters.
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    RECOMMENDED, and Joe sells it :)
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,041
    The Borders
    +2,518
    Hello MacReady
    John Sim (of JS Technology) is a frequent contributor to the AVForums.
    John's converters, switchers and distribution products have many fans and crucially John is only ever a phone call or email away if you ever run into a problem.
    You'll have no problems with your system if you install a JS Technology RGB converter + distribution amp.
    Best regards
    Joe
  10. MacReady
    MacReady
    Jun 25, 2003
    2,224
    +108
    Excellent :thumbsup:
    Thank you very much for all the info and advice :)
  11. MacReady
    MacReady
    Jun 25, 2003
    2,224
    +108
    AAARRGGGHHH...bloody old age is getting to me I tell you !!
    I have completely forgotten about my CLD925 Laserdisc player ! That is not outputting to the projector either and I really would like it to be. Am I right in thinking that the RGB/YUV converter only has one input so I cannot put the Sky+ and the LD player into it?
    I am not going to have to buy two am I so I can convert both signals to YUV :(
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,041
    The Borders
    +2,518
    MacReady
    As long as your Laserdisc player is outputting RGB on SCART then you can 'daisy chain' it via the second SCART socket on the SKY+ Digibox.
    Put the SKY+ box into standby and you'll 'see' the signal being looped via the second SCART socket.
    Best regards
    Joe
  13. MacReady
    MacReady
    Jun 25, 2003
    2,224
    +108
    Ahh...didn't think of that (obviously..lol) Thank you again Joe...you are being a massive help with this mate :thumbsup:
