where to buy my samsung SP50L7HX
Discussion in 'General TV Discussions Forum' started by boharry82, Aug 15, 2005.
  1. boharry82
    boharry82
    hiya all i spose the question is pretty much sumed up in the title :D but yeah were is the best place to buy my SP50L7HX i need to get it on instalments i have found that john lews do the SP50L7HX for 2500 ish with a free 5 year waranty and will price match any retail store i am told, but not online stores plus 9 months intrest free payments, also i dont know if they cover the bulb at jl i heard costco sell it a 1800 but im not sure about the waranty. so if any one knows were i can get the SP50L7HX from with a free 5 year waranty witch covers the bulb and i would like it all on instalments for less then 2000, please let me know thanks a lot. regards simon :smashin:
  2. showcase
    showcase
    go to comet they will price match and give a 5 years gurantee, they do pretty good deals, if u get the right sales person, and it depends which shop u go to!!!!!
    anyway good hunting and best of luck
  3. boharry82
    boharry82
    but where can i get them to match the price? the best price i can find in a store is 24.......somthing but on line i can get 18......somthing and most places only match the price from a actual retail store and not on line.... :confused:
  4. kmhtkmhtkmht
    kmhtkmhtkmht
    Just buy it online. It's cheaper - always will be.
  5. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    With advice like that you'd probably spend your time & money travelling the length & breadth of the country !!! :eek:
    It certainly does depend on the particular branch of a highstreet chain & the salesperson. If you're going to do something like this then if you go into a couple of Comets for example & have no joy do what kmhtkmhtkmht suggested & buy on-line. :D
    Anyway boharry82 should have done a search on the threads posted in this forum so far as already much has been discussed about 'where to buy' & 'extended warranties' & all this stuff about '....is the bulb covered or isn't it' ..... :rolleyes:
