Where to buy miniDV tapes?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by StephenR, Jul 31, 2001.
  1. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Does anyone know of a good place to buy miniDV tapes mail order? I am looking for 60 minute ones, preferably Sony. I remember buying my last batch of tapes mail order for a very reasonable price but I can't find the phone number.
  2. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    hi stephen
    these are the cheapest guys i know .
    i dont know wether they do mail order though they are called kvj fairdeal and they are based in whitechapel their phone number is 0207 247 6029
    price for a 60 min jvc dv is £3.25 panasonic the same price sony are £4.99
    hope this helps
    jason
  3. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Thanks for that, I'll give them a try. If not I've found out that Jessops do a Sony 5 pack for £30 i.e. £6 per tape.
  4. Guest
    probably a long way to go but the States is cheap of course!
    Cheers<br />Dave
  5. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Try <a href="http://www.pricebuster.org.uk" target="_blank">www.pricebuster.org.uk</a>
    Panasonic DVM60 £2.95 ea
    Regards
