where to buy iscan pro?Is it as good as htpc?
Discussion in 'Projectors, Screens & Video Processors' started by woody183, May 28, 2002.
  1. woody183
    woody183
    Where can you buy the iscan pro? I have the panny but dont want to use my pc (in a different room).Does the iscan give the same pic quality as a htpc?One other question is .. If i do use the iscan is there any problems with the sound being out of sinc?
    cheers woods!
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,769
    7
    2
    167
    Birmingham, UK
    +10,673
    It depends on the resolution you are wanting to use. HCPCs will do a variety of resolutions and most people like to use higher resolutions like 800x600 and 1280x720. I don't believe the IScan can do these resolutions. I'm not sure, though. Therefore if the best resolution for your display device is beyond the IScan's capability then it's not even an option worth considering.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    An Iscan has excellent de-interlacing capabilities. Even fed by the best DVD player it is unlikely to get the level of detail you would with a PC though.
    Using it with a Panny? ae100 or plasma, is likely to offer superior performance to a direct feed from a DVD or other sources.
    In instances where there are already lipsync issues on the source material, ie badly mastered DVD's or dodgy Sky broadcasts, the field buffering used by the I scan may result in noticeable audio delay...but only on very rare occasions I'd think.
    I sell them.
    Gordon
