Where to buy Bravo D1 or Momitsu V880?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kane D Williams, Nov 20, 2003.
  1. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Where in Europe is the best place to buy one of these players? Will they both do PAL as well as NTSC and be region free? Will they now come with the latest firmware that allows for various resolutions other than 720p and 1080i? As anyone tried one of these outputting a 1386x788 picture?
    Which is the best machine?
  2. EmuMannen
    EmuMannen
  3. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    I assume you got the Brainwave? Have you had any problems? How long have you had it and have you upgraded the firmware, or did it come with the latest version? Will it do various resolutions other than 720p and 1080i?
  4. pdgnews
    pdgnews
  5. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Yes it will, although only via DVI I think (don't use the component outputs on mine).
    Cheers, Carl.
  6. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    The Momitsu will output 720p, 768p and 1080i from component, RGBHV and DVI.
    Steve
  7. pdgnews
    pdgnews
    Great! 720p via DVI is exactly what i want. Cheers.
  8. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Anywhere in the UK stock these?
    Anyone tried 768p via DVI with a HS10 projector?
    Suppose it is cheap enough to give it a go anyway!
    Rob
  9. pdgnews
    pdgnews
    Hmm, i've been reading lots of threads over on avsforum and it seems that the momitsu outputs 720p at 60Hz only... so does this mean that PAL DVDs will appear "jerky" at 720p? But then again, the LCD panel refresh rate is also 60Hz... ouch, my head is starting to hurt.
  10. Timmy B
    Timmy B
    I run pal stuff at 60hz from the momitsu and have no problems.
  11. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Anyone using the Yamakawa 365Divx? Any problems?
