Where to buy Blackout Cloth??
Discussion in 'Projectors, Screens & Video Processors' started by robertsage, Aug 16, 2004.
  1. robertsage
    robertsage
    Nov 4, 2003
    79
    9
    I've read plenty of threads on screen building and need to build a screen 2mx1.1m.
    I've decided to opt for a velvet-covered timber frame and stretched blackout cloth as the screen surface (which I may or may no paint depending onthe initial results)
    Can anyone recommend a supplier of blackout cloth and give me an idea of price??? :confused:
    Thanks!!
  2. GlennR
    GlennR
    Jan 22, 2004
    127
    Nottingham
    +4
    Hi Robert,
    I recently purchase some blackout material from Dunelm. http://www.dunelm-mill.co.uk/
    They had a great selection and I purchased 3mts x 1.2mts for a grand total of £7.95. (last of the big Spenders) Make sure you get the white variety as they also do a cream colour as well. Many people on the forum tend to use the fabric side for the screen but I used the polyester side. I am very pleased with results for such a small outlay.
    Glenn
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,248
    UK.
    +2,772
    You should be able to get it from any good curtain shop or haberdashers, or places like Allders (where I got mine).
    Gary.
  4. robertsage
    robertsage
    Nov 4, 2003
    79
    9
    Cheers guys!
  5. inzaman
    inzaman
    Dec 16, 2002
    7,966
    Derby
    +1,034
    Also got mine from Dunhelm, if you have one close by it is definitely worth going as you may see it even cheaper but then again £7.95 is cheap enough :D
  6. robertsage
    robertsage
    Nov 4, 2003
    79
    9
    Do Dunelm Mills do mail order??
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Try a John Lewis store. They usually have it in.
  8. robertsage
    robertsage
    Nov 4, 2003
    79
    9
    Cheers ReTrO - I'll give them a try.
