Where to buy a long power cord for 'PTAE100'?
Discussion in 'Projectors, Screens & Video Processors' started by Rizel23, Mar 26, 2003.
  1. Rizel23
    Rizel23
    Oct 11, 2002
    778
    +23
    Hi, as the above, need a long power cable, anyone know where i can buy one? Cheers, Rizel
  2. powlest
    powlest
    Nov 5, 2002
    97
    11
    Cornwall
    +4
    Can't find them anywhere so I'll be making one up. I can order enough stuff to make a few if you like? :) Whilst on the subject how do other people get power to their projectors? Do you all have to make up long leads or does anyone power them from the nearest ceiling rose?
  3. Dominic
    Dominic
    Mar 2, 2001
    289
    Essex
    +6
    i bought a 2m lead from maplins and then cut off the 3 pin plug and soldered on a 5m lead (with moulded 3 pin plug on the other end), to the untrained eye i have a looong lead...
    couldnt get hold of the clover leaf IEC plug anywhere on its own, all i wanted was to make the entire lead, but had to settle for a cut and shut. works and has been for over 1000hrs
