Question Where to buy a global xiaomi note 4 5x?
Discussion in 'Mobile Phones Forum' started by philv, Nov 14, 2017.
  1. philv
    philv
    Jul 25, 2015
    92
    grantham lincs
    +12
    i want to buy a xiaomi note 4 or 4x.
    But it needs to be the global version and with band 20.
    An official one as installed at the factory with official OTA updates.
    Can anyone recommend a seller in the uk for this?
    I did place an order with gearbest in china.....but gave up on that.
    No response to a query about a phone.
    Placed order, then order caancelled next day with no explanation.
    Weird.
    S...,uk seller please.
    LAstly....anyone know how you can actually tell if a phone has the bands when you receive it?
    Thanks.
  2. depot
    depot
    Dec 10, 2005
    961
    43
    +223
    Ebay or the xiaomi online store at aliexpress, for the bands i can only think to put a pay as you go O2 sim in and see if you get 4g
  3. philv
    philv
    Jul 25, 2015
    92
    grantham lincs
    +12
    Any idea if i need to top up a sim to find out if it can get 4g?
    If i do, it is £15 to check it has band 20.
    Hopefully it works on a new sim with no credit.
  4. philv
    philv
    Jul 25, 2015
    92
    grantham lincs
    +12
    Also, there are quite a few on allieexpress.
    Anyone any idea which is the correct one or has ordered one from there?
    I am after a 64 gb with band b20.
    There are a few on there that seem to be the same spec/color but with slightly different prices. Confusing.
  5. djstu_d
    djstu_d
    Oct 26, 2007
    486
    46
    +194
    Hey,
    I picked one up from miandmore on eBay, around £180 with next day delivery.
    Comes with the global rom and ready to go.....
    4g on a bt PAYG sim works perfectly.
    Hth
  6. philv
    philv
    Jul 25, 2015
    92
    grantham lincs
    +12
    Thanks or the help and advice.
    Ordered.
