Where to buy a "CIT610-0100" (ASUS motherboard SPDIF module) for my HTPC
D
Dan Smiffy
Hiya,
I have an ASUS motherboard with a connection to connect an external SPDIF out module but I can't seem to find the part (a "CIT610-0100") available for sale anywhere - have searched all the usual places - eBuyer; Scan; etc.. Here is a module for Gigabyte motherboards which Scan says works on many others too. I know sod all about how computers work on the inside, am I likely to be able to plug it into my ASUS and listen to DVDs again rather than just lipread?! Any advice gratefully received!
Cheers,
Dan
willo
I have an Asus A8N-VN CSM and have had trouble finding a SPDIF adaptor, on my motherboard its 3 pins. Brought the gigabyte one from scan but the block is for 4 pins. So I stripped the wires and replaced with single ones and attached to the motherboard.
The light for SPDIF works but I'm running Vista 64 and ASUS haven't realeased the drivers so I can only assume it works. Also Vista seems to have trouble putting out sound through SPDIF.
D
Dan Smiffy
Called MediaTV - spoke to a really nice chap who said ASUS don't make their SPDIF thing any more 'cos it had lead in it and they weren't allowed to! Will investigate my bruv modding a Gigabyte one or just buying a cheapo sound card with optical out on it instead.
Many thanks both for the replies!
Dan
It's here but out of stock, suggest you call them to get a date or special order http://www.mediapc.tv/index.html?lmd=39184.634016
mark.carline
Hiya,
Cheers,
Dan
What kind of board is it ?
Does the manual give you the pin outs ?
Is there ANY digital audio outputs on the back of the board ?
If you can find the pin outs of what your board needs then you can compare this with the gigabyte one.
C4man
I've used the Gigabyte bracket on the Asus P5B-VM, it needs a little modifiying as willo mentioned but can be done in 5mins. Works fine.
I used the 4 pin block that's attached to the other connectors (rear, side and sub) as I didn't need them. You can slide out the pins that you don't need and slide in the SPDIF pins, a little messy but ok.
D
Dan Smiffy
Righto I've obtained a Gigabyte bracket from a friend with a soundcard so he didn't need the bracket, a 12CR1-1SPOUT-12), which has optical and RCA on the plate and a 3x2 pin block with three wires coming out of it coloured red, white and black. Assuming this is suitable for my motherboard, where might I get hold of a four pin block to attach to it? Or better still, is there anybody in London who'd do the swapover for me if I brought it over, for a beer or two, pretty please? I'd sooner get an electrician in to change a plug than do it myself because I wouldn't wanna live in a house I've had a hand in doing the electrics for! And the same goes treble for wiring up something I'd plug in my gorgeous new PC.
Cheers,
Dan
D
Dan Smiffy
Chris bless ya, absolutely bless ya! I'll buy that board from Scan and send it you in a SAE when it arrives, or bring it round if you're local / near a tube line?
Thanks a million!
Dan
UPDATE: it's ordered! ETA Thursday :thumbsup:
D
Dan Smiffy
Just bumping my thread to send a big public thankyou to C4Man. Within two days of Scan posting me the Gigabyte motherboard he'd told me to buy he'd received it; modded it and returned it, and it works a treat! Thanks so much, Sir!
Dan.
