Where to audition MS Genie speakers?
Discussion in 'Home Cinema Speakers' started by rajvirdee, Oct 24, 2004.
  1. rajvirdee
    rajvirdee
    I live in High Wycombe and can't seem to find anywhere to hear these speakers.
    The web site give us the Marantz UK HQ address (not very helpful!) as my 'local' dealer.
    If anyone has heard them - please tell me what you thought!
    :thumbsup:
  2. BertRacoon
    BertRacoon
    Oct 10, 2004
    +11
    I asked the same question in another forum a few weeks back (http://www.avforums.com/forums/showthread.php?t=147204&page=3&pp=15&highlight=genie) and the answer I got back was that they were looking into re-structuring their suppliers.
    However I did ring the Marantz HQ number and spoke to a nice lady who told me who all their suppliers were in my area.
    I was also lucky enough to make it to the HiFi show in Manchester this weekend and get a listen to the Genies. Although they were hooked up to a pretty average amp due to them being on the Marantz stand they sounded really good, very clear, and they looked better in the flesh too!
    Now if my local hifi shop can clear their demo room of the stuff that is left from the show I can audition them with the Yamaha AX750SE and I can make doubly sure before I splash out!
    Hope this helps
    Rob
  3. rajvirdee
    rajvirdee
    ...its too late - I've gone for them and should be recieving mine in a week or so!
    Should never trust the reviews, and thats what i've ignorantly done.
  4. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    hey Raj,
    Good on you!
    How much did you get them for and which amp are you going to use to power them and please post a review when you get them and set them up.
    Thanks.
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    I am confident you won't be disapointed- but you do have right of return.
    Currently I freely admit our dealer locater is a bit rubbish but this is partly because dealers who previously didn't touch our stuff with a barge pole are ordering Genie, this means that no list we have is remotely accurate.
  6. rajvirdee
    rajvirdee
    Thanks tons of fun and bbasra
    I paid £800 for the speaker set (couldn't find them any cheaper) and am pairing them with a Denon 2805 Amp (£550). Will this be an ok set up?
    I'll gladly write my thoughts when it all arrives.
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    I think that it should work nicely together- the 05 series Denon's are excellent units and have good current supply to power the Genie's. Marantz's new receivers should be equally good but the Denon is a good choice for film and music.
  8. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    I think that will be a great setup!
    I am going to get these speakers once i have heard them to go with a Denon 3805 as i am getting this amp at a good price. Just need to get the speakers.
    @ Raj, can you also let us know if the speakers come with any cabling, if so, if it is any good?
  9. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    No cabling is supplied other than the sub's mains lead. This is pretty normal practice in our defence.
  10. rajvirdee
    rajvirdee
    Tons of fun - which cabling would u recommend.
    I'm a bit stuck as the rear speaker wires have been chased into the walls - they're the stuff you get with Sony cinema systems (probably poor). I have no choice with these.
    Will it affect the quality significantly?
    (hope not...)
  11. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    i'm also in the same boat as the cabling for my rears are going under my flooring and dont really want to change it....... and my cabling is not really good quality either. will it make a lot of difference?
  12. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    Cabling makes a difference but not an epic one. MS recommend Audioquest Type 2 in this instance (and it worked well at Manchester) but if you can't find it QED original is equally proficient.
  13. Santy
    Santy
    Did anyone try the Genie's with AVR-3805 Denon - I'm dead set on this amp but puzzled over speakers to buy...
    It is a problem getting a decent 'local' (ish) shop to demo Amps / Speakers (I live in Cheshire)...
    If I go for this speaker package though, it may blow all of my plans out of the water...
    Wanted a charcoal P 6 or 7 Series Plasma to go, not keen on Silver Sep system but feel that 3805 looks better in Silver, can anyone advise?
    May push me down the P7 in silver route although black plasma's lok better in my opinion - Doh!
    Confusing Myself now... :confused:
  14. goody
    goody
    hi get mine today to go with my denon 2803
    i payed £799 but got free cable qed 40m + 3m sub cable
    from peter tyson
    ms genies + denon 2803 + pioneer 575 + jvc 32widescreen soon to be p6 or p7 plasma
  15. rajvirdee
    rajvirdee
    I tried to get Hifibitz to match it and they wouldn't !
  16. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    please post review when setup
  17. goody
    goody
    just took them out of box look very nice
    when you come to put them on the wall be very carefull not to unscrew the allen key bolt too far this allows you to move the speakers around to get the bracket in right position but if you do you may lose the plastic nut on the inside of the speaker like i did this ment i had to take my brand new speakers apart to repair them before i had even tried them so be carefull
    goody :lease:
  18. goody
    goody
    hi all set up my genies and are working
    they sound great fills the room with real sound dvd just jump out of the walls
    and music sounds good to jsut be ware of the speaker stands see above post
    but over the moon with them and came in good packets with their own little bag for each speaker they realy look the biz
    phil :)
  19. Santy
    Santy
    Good th know Goody, ordered mine last night from RicherSounds...
    Mating them to a 3805 Denon, really looking forward to it. Is the Sub any good mate, and do the units feel like quality items?
    Santy
  20. goody
    goody
    hi Santy
    yes the sub is v good and the speakers are real quality they are heavy
    just watch the brackets! (see my post above) and they all come with their own bags and the sub comes with that db meter to set it all up over all very very pleased
    phil
  21. Santy
    Santy
    Goody
    Thanks mate, good to hear. You didn't happen to buy from RicherSounds did you? Just wondering whether 7 - 10 day delivery schedule is accurate, running outta time to complete custom install pre-Xmas... :rolleyes:
    Also, what cable did you use mate, what sort of quality? Only thing I haven't ordered...
    Thanks :smashin:
  22. goody
    goody
    hi Santy
    got mine from peter tyson
    had to wait 5 days but i payed £799 but that included 30 metres of qed silver ann and a 5 metre sub cable.
    their offer on web site says free 40m qed micro cable + 3m sub cable
    the silver cable sound great but is hard to cut and strip
    the next best price i came across was at hiway hifi £650 + £15 del
    hope this helps
    goody
  23. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    If adequate demoing areas continue to be a problem, once my Genie is in place, I will be happy to demo for people in the MK/Bucks area.
  24. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    £650 + Del Where?
    do you have a web link or contact number?
  25. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    If anyone in London wants to hear the Genies the Hifi shop next to the Odeon on Tottenham Court Road has got them, can't remember its name unfortunately. They're wired up next to Kef 2005.2s and the source mystically goes through many different AV amps so you can compare them too. They're wired up on the shop floor rather than in a separate room so not at their best, but good for simple comparison.
    They sound lovely, I personally preferred their sound to the eggs...but I have to say I preferred the sound made by full size speakers for music.
  26. Kwman
    Kwman
    Sep 7, 2004
    2,589
    London
    +990
    I got mine from Hi-Way Hi-Fi for £550 and picked them up last week. I opted for the black ones otherwise I would have had to wait for the silver ones. Their number is 020 723 5251, address 318-324 Edgware Rd, London, W2 1DY.
    Haven't set them up as I am currently waiting for my amp to arrive, but I took them out of the box and they look very nice.
    kw
  27. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    How did you manage that as the price on the website is £799.
    Can you please tell me who you had spoken too?
  28. Kwman
    Kwman
    Sep 7, 2004
    2,589
    London
    +990
    Hi bbasra
    I ordered my genies on around the 11th Oct. At that time they were advertised on their website for £550.00
    They didn't have any stock so I had to keep phoning them to ask if they had any stock. Once they did I said I would come down and pick them up, which was about 2 weeks ago now.
    I did post about the price when i first saw them advertised for that price a few weeks ago on this forum, as i believed it was a good price.
    Anyway speak to "Ken" he normally gives good offers.
    kw
  29. bbasra
    bbasra
    Sep 15, 2004
    1,665
    48
    Hounslow
    +44
    :oops: I done the same thing as you and now have to take them apart/ :mad:
    Did you just losen the two allen key bolts and then they come apart?
    Was it very easy to do?
  30. Spartacus
    Spartacus
    Nov 22, 2004
    113
    +4
    Was tempted....but then managed to aquire a Canton 4.25 setup for £825. No competition imo.
