where..sorry when is 10..
Discussion in 'Plasma TVs Forum' started by Phill1978, May 2, 2007.
  1. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    1080p coming to plasma and which model.
    links please
    :thumbsup:
  2. Briggott
    Briggott
    May 21, 2006
    76
    London
    +8
    Models I know of at the moment are:
    LG 71PY1M - 71" about £20k
    Pioneer PDP5000EX - 50" about £5k
    Panasonic PZ700 Range from 42" up to 103":eek: no idea of pricing
  3. Jonstone
    Jonstone
    Feb 12, 2006
    4,159
    Prestatyn
    +544
    If you are thinking of buying a 1080p plasma then please do yourself a favour and do the following.
    Take an hd source, like a PS3 for example, and go and test it on a 1080p plasma from your normal viewing distance.
    Then take the same PS3 and test it on a 1024x768 plasma, again from your normal viewing distance.
    (And for fun if you can find an sd plasma try it on that too, I think you will be surprised how little difference their actually is in pq even at this much lower res if the screen can handle an hd input)
    Then if you like do the same with lcd's
    If you can see enough of a difference between the lower and higher definition sets to justify paying more than double for it then fine buy the 1080p screen.
    If not then save yourself a fortune and buy the lower resolution plasma, pocket the difference and then buy a larger 1080p tv in a years time which you may actually be able to see a difference on for the same total outlay as the 1080p screen would cost you now.
    No doubt there are some people who can tell the difference in normal viewing, but the majority of people won't unless they sit unusually close to the screen.
    Just don't be swept along by the 'more pixels is better' arguement, use your own eyes and make a proper personal judgement.
  4. s1m0n
    s1m0n
    Panasonic full HD 50PZ700 should be available to see by the end of May...and the 42" following in June...I'm curious if the new Viera 2 pro chip will do something about the 'colour banding' problem that still affects Pannys...otherwise it's gonna be a Pioneer or PH9 for me:rolleyes:
  5. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    You forgot to mention the current PF9 as one.
  6. s1m0n
    s1m0n
    Don't know if you trawl the threads Sinelanguage, but a review link of the upcoming Panasonic 50PZ700 (50" full HD), which is priced at £2420 at Dabs.com (although not yet available)...also said Pioneer had lowered it's price of the PRO-FD1 (the US equivalent of the 5000EX 50" full HD) from $8000 (about £4000) down to $5000 (only about £2500)...no news on this price drop in the UK!...
    ...The Panasonic professional panel (50PF9), that pjskel mentions above, is priced about £4000...although you'd need to add optional boards/stand/mount to get a true price...
    ...there are larger Panasonic 'commercial' displays available, up to the c.£60-70K 103"...footballers only need apply....:D
  7. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    thats not a problem mate i am a footballer :rotfl:
  8. s1m0n
    s1m0n
    lol:D ....hope you enjoy your new 103"!!
