So, no CD Player, no BluRay player, all those functions are being provided by your game box?
With your budget on the high side (~$2000) you can get a pretty fair Surround Sound system. There is no denying the immersive effects of Surround Sound for movies. In short Surround Sound surrounds you with sound.
On the lower end, as seen in my example, you can get a very nice Stereo system. (~$800).
Keep in mind I have and favor a Stereo system, as you get much better sound quality for your money. I also favor Floorstanding speakers over Bookshelf/Sub partly because there are few to no stereo amps that have internal Electronic Bass Management. At the same time I do recognize the value of Surround Sound for movies. I just choose quality over quantity. But remember on the high side of your budget, you can get a pretty decent Surround Sound system.
Most AV Receivers do have Electronic Bass Management; in the simplest term this means internal to the amp, you can control the crossover not only to the Sub but to the Front speakers as well. With a typical stereo system, the Front and Sub are always going to be running in parallel, there is not way to limit the frequencies that go to the front speakers. That makes integrating the Sub and Front more difficult as you are limited to the manual controls built into the Sub.
On a Sub you typically have THREE controls - Volume, Crossover Frequencies, and Phase. In case, for the moment we need not be concerned with Phase. This is just my self-invented method, but I would start with the Subwoofer set to 80hz, then with the volume essentially off, bring the volume up until what you are hearing sound reasonably balanced. Leave the Volume Setting at this new level, turn the Crossover down as low as it will go, then gradually bring the crossover frequency up until you feel you have the best blend of Front and Sub. Leave the Crossover at this new setting, and bring the Volume down and back up again, trying to find the best balance. Then repeat with the Crossover. You are trying to zero in on the best balance of sound, the best blend of the Sub and Front speakers. I don't imagine it would be necessary to run through this process more than about 3 times to find the best Blend of the Front/Sub, and the best blend with your personal taste.
I doesn't seem to me that you are looking for over-hyped over-amped bass, so I would recommend Floorstanding where the Bass and the rest of the frequencies are already blended together by expert engineers back at the speaker factory.
Again, just to illustrate the possibilities, in floorstanding these have caught my eye -
Polk Audio TSx440T (Cherry) Floor-standing speaker at Crutchfield.com
Polk Audio TSx550T (Cherry) Floor-standing speaker at Crutchfield.com
Difficult, at least for me, to find a place to audition these speaker, but I would expect good things from them. At US$700 to $1000/pair, they would leave you plenty of money for a good Stereo amp, and would bring you in well under budget.
This next speaker is one model series above the TSx listed above, though not the latest model, it should also be an excellent speaker -
Polk Audio RTi A7 (Cherry) Floor-standing speaker at Crutchfield.com
If you want a little more crispness and presence in the Voice range, then consider the Klipsch -
Klipsch Reference RF-62 II (Cherry) Floor-standing speaker at Crutchfield.com
Klipsch Reference RF-62 II (Black) Floor-standing speaker at Crutchfield.com
Klipsch Reference RF-82 II (Cherry) Floor-standing speaker at Crutchfield.com
The horn Mid/Tweeter really has a presence that cut through the clutter. A very common speaker, and should be easy to audition. I'm not sure about the prices, they don't seem very consistent. But the RF-62 in cherry at $399 each, and the larger RF-82 at $499 each are exceptional deals.
As far as an amp, I would still recommend the Yamaha RN500, it has an internal DAC with Optical and Coaxial connections, 80w/channel, and the Computer Network Streaming (DLNA & Apple Airplay) is a real bonus, especially if you have a lot of digital music.
An alternative to the Yamaha RN500 would be the Onkyo TX-8050 with a similar feature set -
Onkyo TX-8050 AM/FM/Internet radio receiver at Crutchfield.com
The TX-8050 is an older product that has been on the market longer which accounts for its lower price.
The external DAC, found in either of these units, on its own would sell for about US$300. -
Cambridge Audio DacMagic 100 (Silver) Stereo digital-to-analog converter with asynchronous USB input at Crutchfield.com
The nearest Yamaha Reciever without DAC or Streaming would be the R-S500 -
Yamaha R-S500 Stereo receiver at Crutchfield.com
As you can see, if you add a DAC to that, you are spending more money and don't have Streaming.
Now, if you decide to go the Surround Sound route, you don't need floorstanding speakers; bookshelf/Sub are a more functional choice. Good bookshelf will still do a very good job for music, and for movies the Sub will add real weight to the sound tracks.
In Home Cinema Recievers, you really need to spend at bare minimum $500 -
Yamaha RX-V677 7.2-channel home theater receiver with Wi-Fi® and Apple AirPlay® at Crutchfield.com
Yamaha AVENTAGE RX-A730 7.2-channel home theater receiver with Apple AirPlay® at Crutchfield.com
Yamaha RX-V775WA 7.2-channel home theater receiver with Apple AirPlay® and included Wi-Fi® at Crutchfield.com
Yamaha AVENTAGE RX-A830 7.2-channel home theater receiver with Apple AirPlay® at Crutchfield.com
Denon AVR-X3000 7.2-channel home theater receiver with Apple AirPlay® at Crutchfield.com
Yamaha AVENTAGE RX-A1030 7.2-channel home theater receiver with Apple AirPlay® at Crutchfield.com
If you spend say $750 to $850 on the AV Receiver, that leaves about $1200 for speakers. Other brands are possible, but I favor Yamaha, Denon, and Marantz, though there are Cambridge, and NAD in your price range.
So, let's see if we can put together a speaker system. Again, at this stage I'm more illustrating the possibilities than making recommendations. As soon as you decide the direction you want to go, we can get down to more specific recommendations.
FRONT -
Polk Audio TSx220B (Cherry) Bookshelf speakers at Crutchfield.com
CENTER -
Polk Audio TSx150C (Cherry) Center channel speaker at Crutchfield.com
REAR/SIDE -
Polk Audio TSx110B (Cherry) Bookshelf speakers at Crutchfield.com
SUBWOOFER -
Polk Audio PSW110 (Black) Powered subwoofer at Crutchfield.com
Polk Audio PSW111 Ultra-compact powered subwoofer at Crutchfield.com
Polk Audio PSW125 (Black) Powered subwoofer at Crutchfield.com
Which Sub you choose will depend on budget and the size you need. For simplicity, I will use the middle Sub at $299
So, we have this -
$300/pr = Polk TSx220 (Front)
$230/pr = Polk TSx110 (surround)
$200/ea = Polk TSx150C (center)
$300/ea = Polk PSW111 (Sub)
$1030 = Total
The same thing could be done with Infinity Primus or Klipsch RF speakers, and possibly a few other good speakers at a very similar price.
Combine those speakers with the AV Receiver of your choice, and you should have a very good system.
If you want to boost the above AV system, then consider smaller floorstanding in front -
Polk Audio TSx330T (Cherry) Floor-standing speaker at Crutchfield.com
These would add about $200 to the overall system price listed above for a new total of about £1230/set. That still allows you a substantial amount for the AV Receiver while staying under your maximum budget.
So, as your see, it is as I originally said, you can get a AV Surround system that would be undoubtedly good near the top of your budget. But at near the middle of your budget, you can get a pretty stunning Stereo system.
These Polk RTI-A7 are very good at about $1000/pr and the Yamaha RN500 at $550, still leaves you well shy of your highest suggested budget. The RTi are one model line above the TSx, and should be extremely impressive with very deep bass down to 30hz or a bit less at -6dB -
RTiA7 - Floorstanding | Polk Audio®
In the Polk TSx series -
TSx | Polk Audio®
TSx550T - Floorstanding | Polk Audio®
TSx440T - Floorstanding | Polk Audio®
TSx330T - Floorstanding | Polk Audio®
The TSX550 have response down very close to 30hz or a bit less at -6dB. The TSx440 have response down to about 35hz at -6dB, still reasonably good. the TSx300 has response down to about 38hz at -6dB, which is still decent for music.
The original suggestion of the
Yamaha RN500 ($550) and the
Wharfedale Diamond 10.2 ($450/pr) bookshelf will give you good bass down to 40hz and with a total price of about $1000, which puts you very much on the lower end of your budget.
You can get a Surround Sound system for a few hundred less, by going to a lower AV Receiver, and you will probably be satisfied. But you really shouldn't go less than about $500 on the AV Receiver.
The AV Receiver will have simplified connection (HDMI, Optical, Coaxial), it will have Network Streaming, and it will have internal Electronic Bass Management. But you can't expect a $500 AV Receiver to be the equal of a $500 Stereo receiver, which is why I suggested an AV Receiver in the $750 to $850 range.
To some extent it gets down to the size of the available space, and how you want to and are able to use it.
Any of the system I outlined would be a very good system. So, the only thing left to do is to narrow down your specific want and needs. Once you know what you want, then you can get what you want.
Again, I suggest either a Stereo with Digital Inputs and floorstanding speaker, or an AV amp with a bookshelf/Sub combination.
Steve/bluewizard
