Where should I get my next Gaming PC in the UK from?
Discussion in 'PC Gaming & Rigs' started by Spud_Launcer, Apr 28, 2007.
  1. Spud_Launcer
    Spud_Launcer
    Hey I’m looking for some advise on getting a new Gaming PC in the UK.
    I cant really build my own, I know a bit but I don’t want to break something.
    I saw few I liked the look of and came recommended, I have £3,000 to play with:
    The Monkey System for £2695: http://www.monkeyware.co.uk/shop/howler.php
    Or the alienware for £3388
    perating System: Genuine Windows® Vista Ultimate - English
    Warranty: AlienCare 1-Year Free Phone 24/7 and Collect & Return
    Chassis: Alienware® P2 ALX Chassis - Space Black
    Chassis Upgrades: Alienware® AlienIce™ 3.0 Video Cooling + AlienFX™ System Lighting + Alienware® High-Performance Liquid Cooling
    Power Supply: Alienware® 1000 Watt Multi-GPU Approved Power Supply - UK Powercord
    Motherboard: Alienware® Approved NVIDIA nForce 590 SLI Motherboard
    Processor: AMD Athlon™ 64 X2 6000+ Processor with HyperTransport and Dual Core Technology
    Memory: 4GB Low Latency DDR2 Performance SDRAM at 800MHz - 4 x 1024MB
    Video Card: Dual 768MB NVIDIA® GeForce™ 8800 GTX - SLI Enabled
    Physics Processing Unit : AGEIA PhysX™ Physics Processing Unit PCI-E
    Video Optimiser: AlienAdrenaline: Video Performance
    System Drive: Extreme Performance (RAID 0) - 500 GB Serial ATA 3 Gbit/s 7,200 RPM with 2 x 8MB Cache (2 x 250GB)
    Optical Drive One: 18x Dual Layer DVD±R/W Drive
    Sound Card: Creative Sound Blaster® X-Fi Xtreme Gamer
    Removable Storage: Alienware® 28-in-1 Digital Media Reader / Writer
    Or are there better places?
  2. booyaka
    booyaka
    Sep 26, 2002
    11,062
    +3,585
    £3k is total overkill for a gaming PC
    half of that is way enough for a top end pc.
    I would stear clear of Alienware etc as they are way way way to expensive. £3k for an AMD cpu !!!!:eek: :eek:
    If you have a litte bit of knowledge about computers - it's very simple to build your own pc. I would suggest this is a great route to go down and also you would be able to select all the components you wish to have not just a prebuilt system with anything in it.
    if not check out this system
    http://www.overclockers.co.uk/showproduct.php?prodid=FS-032-OK&groupid=43&catid=781&subcat=
    £1700 cheaper and and also a miles better CPU.
    2gb of ram is plently for gaming.
  3. Mojo-Filter
    Mojo-Filter
    Jun 20, 2005
    28
    Scotland
    If you don't want to build it yourself...
    http://www.cyberpowersystem.co.uk/
    Don't bother with a physics card though, waste of time. And Intel chips are the way to go at the mo. :smashin:
  4. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    I'd say that most of the components are a complete waste of time in the original configuration.
    No point getting a dx10 gfx card at the moment, upgrade later on when the radeon dx10 come out and the prices start dropping.
    Again 4GB ram is total overkill, 2GB is the ceiling at the moment.
    Physics card is a waste of money as has been mentioned as is a 1kW psu.
    Even a dedicated sound card is a waste of money. My motherboard outputs 7.1 and has an optical out, so just make sure you get a high end motherboard.
  5. alphaomega16
    alphaomega16
    May 17, 2005
    14,121
    163
    Southend on sea
    +3,761
  6. broona
    broona
    Aug 26, 2004
    5,701
    Hexham
    +710
  7. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,441
    2
    In a secret location with Jennifer Lawrence
    +11,771
    Spending 3K on a gaming PC is a bit like buying a brand new car. As soon as you drive it off the forecourt it has lost 25% of it's value. Same with a top end gaming PC. Within a month or so you could probably get the same thing for a grand less. But if you have money to burn then the choice is yours.
  8. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    if you dont want to build it yourself and want good backup, dont bother with Alienware as they are now owned by Dell, just go for the Dell XPS machines.....components will be the same, just in a Dell case which means the cost should be around 25% cheaper....
    backup is better too on the XPS machines than with Dells cheap machines....like any company there is the chance of hiccups, but given the sheer volume Dell ship in they have a pretty good level of quality...
    otherwise consider overclockers.co.uk, i buy individual components from them and so far no problems......
  9. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    Alienware is a complete rip off. It's just for people to go "I've got an alienware pc" kinda like buying something big and expensive to over compensate for something else in life :cool:
    IMO only a pure idiot buys alienware, >£1000 is too much money for a pc unless you're using it to do extremely complicated calculations or cure AIDS
  10. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
  11. alphaomega16
    alphaomega16
    May 17, 2005
    14,121
    163
    Southend on sea
    +3,761
    No offence but I personally dont like this site because of the lack of customization but I will say one thing about this site that kicks ass.
    They have made a selection of skins available that they will put on the case which really kicks arse.
  12. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    Yep, their choice of skins is really cool. They've only just setup shop so I'm sure they'll allow customisation soon enough!
  13. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    im still trying to figure out why that should cost 3 grand. my pc cost just over half that, and its better. well apart from a 2nd gtx lol.
  14. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    Who knows, maybe customer service or quality of parts?
  15. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    i think the price comes down to them making sure the components all work in harmony in the system......if you build your own you dont know that for sure, lets face it, im sure most folks on here who have built a PC have found their RAM doesnt suit the mobo too well or similar such problems.....
    but, Dell/Alienware/etc pick some components, make sure they work together and then buy the job lot.....saves you spending weeks testing the system....
  16. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    Good point Knyght_byte and it's one of the main reasons I would unlikely build my own system. Prices are so competitive out there that there is not so much differential between sourcing the parts yourself and custom build.
    As well as the price, I just don't have the time to do all the testing to make sure it all works.
  17. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    I actually enjoy building pc's. Maybe I am just a bit strange. :oops: :D
  18. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    are you seriously telling me it would cost nearly 3.5k to build that alienware pc?
    http://www.overclockers.co.uk/showproduct.php?prodid=FS-018-OK&groupid=43&catid=781&subcat=
    id rather have that, for a fair chunk less, and its far better spec'd.
  19. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    I would love to do it one day. But right now, with work and a three-month old son, I just couldn't bear the extra headache if things went wrong!
  20. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Fair enough mate. So far no issues with my builds but, never say never. :smashin:
    I think I just like tinkering with my pc and picking all my parts. I used to buy from Mesh pc's before I started building my own. They always did good pc. I would definitely recommend them.
  21. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    Yep, owned two Mesh's myself and never had any problems (despite what many say).
    This is the first time I've gone for Dell, I needed a budget solution, and so far so good. Not as customisable as I'd like, but can't complain for the price!
  22. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Dells are cheap but very restrictive. Not the best if you want to upgrade or get extra performance. Great for a budget web surfer though.
  23. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    We have two PC's in our house, one gaming and one surfer/general use one for the wife. Tbh they both need changing but I'm not looking to upgrade the gaming one until quad core chips are more commonplace (and utilised).
    This Dell will keep things going until then. I'll add a HD 2600 gfx card and Samsung 22" monitor and then I'll be happy (for now)!
  24. Polaris
    Polaris
    Jan 17, 2006
    41
    I have just upgraded this system from Scan in bolton, it has had a great review in computeractive and I think its great value for a water cooled system with all the tasty trimmings! I have spoken to scan and they will swap out the XFX 8800GTX XXX for the newer "ultra" model for a tenner less!?!?! and will change vista 32bit for the 64bit edition so that 4gb ram is usable and also they overclock it as standard... I think its a red hot machine for the money imo?? what do you think?
    3XS OC-GTS system £1,296.16 £1,522.99
    1 LN17156 Coolermaster Mystique RC-631-KWN1 - Black Alu Window with preinstalled watercooling – Ready2Go
    1 LN18734 **3XS-OC-GTS SYSTEM**
    1 LN17547 Abit Fatal1ty FP-IN9 SLI NF650i SLi S775 PCI-E(x16) 533/667/800 MHz DDR2, SATA II SATA RAID ATX
    1 LN15215 620W Corsair HX Series Modular SLi PSU, ATX, EPS 12V, whisper quiet, 5 year warranty
    1 LN176 Scan System Configuration
    1 LN1272 Scan 3XS System - 1year Onsite Warranty (Mainland UK)
    3 LN7920 60cm Akasa Serial ATA Cable ATA150/300
    2 LN13663 120mm Sharkoon 2000 "Golf Ball" Quiet Case Fan
    1 LN10469 *No Custom Colour Required*
    1 LN15050 Intel Core 2 Duo E6700, Socket 775, 2.67 GHz, 1066MHz FSB, 4MB Cache, Retail
    1 LN18576 4GB (4x1GB) Corsair XMS2 Dominator, DDR2 PC2-6400 (800), Non-ECC Unbuffered, CAS 5-5-5-15, DHX
    1 LN17055 768Mb XFX 8800GTX XXX, PCI-E (x16), Mem 2000 MHz, GPU 630 MHz, Dual DVI/HDTV
    1 LN16546 500 Gb Samsung HD501LJ Spinpoint T, SATA300, 7200 rpm, 16MB Cache, 8.9 ms, NCQ
    1 LN5487 Scan Black Internal All in 1 (50+) Card Reader (SM/MMC/SD/mSD/CF/Mdrive/MS/ MSPro/MSDuo/MSDuoP)
    1 LN15686 Samsung SH-S182M/BEBN 18x DVD±R, 8x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, IDE, Black, OEM, LS
    * Soundcard (Onboard option only)
    1 LN17167 Microsoft Windows Vista Home Premium 32Bit 1Pk OEM (DVD)
    1 LN9187 NVIDIA DVD - Bronze edition - Dolby 2.1 DVD Decoder Software MCE Certified
    1 LN17450 MS OFFICE 2007 60 Day TRIAL Home&Student
    1 LN11918 Logitech G15 Keyboard "The Daddy of Gaming keyboards" inc Programable & backlit keys, LCD Screen UK
    1 LN16147 Logitech MX Revolution, Cordless, Laser, 2000 dpi, USB 1.1/2.0 PS2, 6 Buttons, Black
  25. JamesU2002
    JamesU2002
    Jul 25, 2005
    675
    +11
    Looks good but I would avoid Scan at the minute. Seem to have gone down hill since I last used them.
    Nothing seems to be instock, takes years to reply to emails and lots of bad posts about them on forums.
    Was trying to spec a system up on there website but its an extremely hard affair. Especially if you don't want water-cooling but want an 8800GTX!
  26. Adails
    Adails
  27. JamesU2002
    JamesU2002
    Jul 25, 2005
    675
    +11
    What case do you choose? Any pics?
  28. Polaris
    Polaris
    Jan 17, 2006
    41
    I know what you mean, I only live down the road from them and there queing system isn't much better!! They have however confirmed that al the system parts are in stock and can be built whenever?! I did look at the comparable priced machine at http://www.pcspecialist.co.uk but it doesnt pack nowere near the same spec... I may have to melt the plastic once again and go scan :suicide: just got to get me a 24" dell flat screen and that should be me done for another 4 years...? :thumbsup:
  29. Adails
    Adails
    Not too many cases to choose from. http://www.pcspecialist.co.uk/index.php?page=imagesindex Have just read in the testimonials that some guy supplied his own case for his build. Think I will do that when I order my next one.
  30. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    Don't choose aria.co.uk whoever you do decide to buy from. I had the enjoyment of a 3 1/2 month clawing my money back through my credit card ordeal that was nice.
