Where is the VGA in on the PWD6?
Discussion in 'Plasma TVs Forum' started by steve 111, May 20, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Read somewhere on these forums that the VGA socket is on the front of the PWD6. I find this hard to believe, can some of you PWD6 owners confirm where it is please.
    Many thanks.
  2. wattsj
    wattsj
    It's not strictly on the front but on the underside towards the left (if looking from the front !).
  3. Ianc
    Ianc
    Pe30 (which is same screen in different cabinet so maybe discussed on same thread) does have its VGA input right out front so you cant use it without it looking awful and has been discussed a lot that this is a pain... Pe30 is the "tv" version of the PW6 apparently ..
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    To clarify:- the PWD6 has it's VGA socket downward facing, at the back of the plasma, about a foot in from the left as you look at the front of the screen. The three terminal board slots are then to the right of that.
    Panasonic 42PWD6 page with terminal board pic
    The PE30 (TV) has it's VGA in the front flap with AV4 SVHS and CVBS connections.
  5. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Thankfully, the socket is on the rear on the PW series screens.
    The PA models have this on the front, fine if you occasionally connect a notebook but useless if you wish to use it permanently.
    All the best,
    Dr John Sim.
  6. Ancillotti
    Ancillotti
    It's a shame that the VGA port is on the front of the PE30, as connecting a RGBtoVGA convertor is going to be an eye-sore with the exposed cable.
    I've noticed that my PE30 seems to automatically change aspect depending on what channel you are viewing. In some cases this is a good thing - When I was watching 'The Fugitive' on TCM the automated aspect resulted in removing the borders and TCM logo whilst not stretching the images onscreen. However it would seem that most programs on Sky One/Mix and Paramount result in the television constantly changing aspect back and forth every few seconds, even if I change to 16:9 manually.
    Someone told me this was due to using a RGB SCART input. So my question is, will a JS RGB to Component converter stop the everchanging aspect that occurs on a minority of channels? Thanks :)
  7. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    It should do, there's no widescreen pin on this.
    All the best,
    John.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    cutting the pin off your scart is a much cheaper alternative tho!
  9. Ancillotti
    Ancillotti
    Yeah, John (Symanski) said something about removing pin 8 - So I'm going to practice/test this by using a cheap SCART cable that I have found lying about ... :)
    Thanks!
