Where is the Tripod Mount?
Tinderbox (UK)
Hi guy`s
I bought this cheap projector, an "Cheerlux C6" it works great, and i like it, but i would like to put it on an tripod short term to raise it up off the table, and mount it to the ceiling long term.
Anybody know how i can do this.
John.
Tinderbox (UK)
No they don't screw off, I removed the black rubber foot, but it`s blank underneath.
John.
hippy240980
I think you will need to get creative with some straps or something then. Does the projector have options in the settings menu to be able to hang it upside down from the ceiling? Or will it be best to make a shelf and tilt the projector down and use a keystone adjustment.
Tinderbox (UK)
Hi.
It has a tilt setting in the menu, that turns the image upside down, but it works only on external inputs,hdmi,PC,Av but not the built in media player.
I have emailed the seller.
John.
